RSP Monitoring profile QOS Source set to Host Name is not generating alarms with the <Host Name>
Alarms are instead being generated with the default QOS Source; <RSP Profile Name> + <HostName> for Host Name and Source fields.
Example:
Any UIM version
1. Launch IM
2. Find and select the robot with the rsp probe
3. Select the controller probe and launch the Probe Utility using the Ctrl+P
4. Click on the Option icon
5. Then enable the Export Mode and click OK
6. Click on the Probe commandset pulldown menu, select _nis_cache_clean and click on the Play button.
Make sure that Command status shows OK after clicking the Play button
7. Click on the Probe commandset pulldown menu again and select _reset_device_id_and_restart, click on the Play button.
8. Close the Probe Utility menu and check the RSP alarms to confirm that Source and Host name show the target server names
