SD-WAN Edge interface default route metric calculation
Article ID: 371621
Updated On: 07-15-2024
VMware VeloCloud SD-WAN VMware VeloCloud SD-WAN Edge Appliance VMware SD-WAN by VeloCloud
When a gateway is configured/learned by DHCP or PPPOE, SD-WAN Edge will install a default route in Linux kernel route table with a specific metric. Customer can review the route table with command route -n. Sometimes the route table mess up if metric is calculated wrong and cause some unexpected behaviors.
All supported VMware by Broadcom SD-WAN Edge versions
N/A
Below is the calculation of default route metric:
1. Different type of interface maps to different metric offset. Below is the mapping:
  • GE:2
  • INTERNET:2
  • SFP:30
  • CELL:50
  • USB:60
  • PPPOE interface depends on the interface name after "pppoe-". For example, pppoe-ge5 will be treated as ge5 to calculate the metric
2. Base metric is ID of the interface, for example, base metric of GE5 is 5,  base metric of GE3 is 3.
3. Default route metric is Interface Metric=base metric+metric offset
For example, GE3's interface metric is 3+2=5. SFP1's interface metric is 1+30=31. In case of virtual SD-WAN edge, it uses logical name instead of physical name. For example, physical interface eth3 is mapping to logical name GE5,   SD-WAN edge calculates the metric as GE5, so the metric of that interface is 5+2=7.
Regarding sub interface, the first sub interface metric is "sub-interface offset+(max subif)*(base metric)+1", for all subsequent sub-interfaces under same parent interface, the metric of each sub-interface increases by 1. The sub-interface ID in irrelevant in sub-interface metric calculation.
sub-interface offset is a fixed value 264.
max subif is different across releases:
  • Release 4.5/5.0/5.1=64
  • Release 5.2/5.4/6.0=132
For example, a SD-WAN edge running on 5.4, GE1 has 2 sub-interface, GE1:100 and GE1:105. The sub-interface metric of GE1:100 is 264+132*1+1=397, sub-interface metric of GE1:105 is 264+132*1+1+1=398.
