In MUX, the Help and the Question Mark icon Menu, will open differently based on whether or not the user is an admin user.
The admin user must have the below permissions to be considered "admin" for the Help menu:
What is the expected behavior for each user type regarding the Help Menu?
Clarity 16.2.2, 16.2.3, 16.3.0
The functionality will be updated in 16.2.3.2 and 16.3.0.1 to allow all users to be able to access ICE from the ? button
Note: If you notice that the above behavior is not matching what you are seeing, and you have just started setting up Help and ICE, make sure ICE is set up correctly:
ICE / Help menu Troubleshooting
Clarity Help Icon Displayed But Not Responding or ICE does not load completely
