Client Tools 14.5 encoding problem when doing MERGE
Article ID: 371354
CA Identity Suite
There is a problem with the SBT MERGE functionality in the Client Tools 14.5 if the source configurations (rdb/udb) are encoded as ANSI.
The MERGE will then fail since the target configuration will be encoded as UTF-8.
This happens even though we have set the File Encoding Support to ANSI in the Client Tools.
We see the same behavior also if doing the Merge using the Client Tools GUI.
Error from output log below:
12/04/2024 13:15:42 - Error (Line 19): Wrong resource name ('TESTÃ…--RACF (test)') specified for the resource 0 ('TESTÃ…--RACF (test)' is expected)
Release : 14.5
Component : CA Identity Suite Virtual Appliance
Engineering team provided a hotfix (HF-DE604919-DE605221-DE604947.zip) to resolve this issue. If you are facing the same issue then please create a case and request for the fix.
