Automated_deployment_engine does not start after deploying from Admin Console
Article ID: 371030
Updated On: 06-28-2024
After deploying automated_deployment_engine through Admin Console, the ADE does not properly start and this message is visible in the log:
"..... [2064] Controller: Max. restarts reached for probe 'automated_deployment_engine' (command = <startup java>)"
Deploying the ADE probe from the IM works fine.
DX UIM 20.4.x, 23.4.x
ADE probe has a simple limitation - it cannot install itself as it needs to replace the new binary of itself and restart again using the new binary. It is not specific to 23.4.1.1, the same behavior is seen for earlier versions also.
Use IM when updating ADE probe.
