UTS Conversion does not drop obsolete PTDB objects
Article ID: 370603
DATABASE MANAGEMENT SOLUTIONS FOR DB2 FOR Z/OS
When the Database Management Solutions for Db2 for z/OS Post Install Compare and Create Db2 Objects tasks are executed to perform the UTS conversion of the PTDB,
it does not drop the obsolete objects. In the DDL script executed by the Create task (ssid0001). REORGs are performed on the obsolete tablespaces even though they do
not contain any tables and therefore no data.
UTS conversion implemented by PTFs LU09808 to LU09819.
The REORG is still required for the now obsolete objects. This is a Db2 requirement.
The procedure to move a table from a segmented tablespace to UTS using the new MOVE TABLE option is to issue an ALTER TABLESPACE source-non-UTS MOVE TABLE to
target-UTS followed by REORG of the source Tablespace in order to materialize the MOVE TABLE operation. When the ALTER TABLESPACE statement is issued, the table is
still not physically moved to UTS and that is why the source Tablespace is placed in pending REORG state.
For example, as part of the conversion of the source segmented Tablespace PTITSANA to target UTS PTUTSANA the following occurs:
ALTER TABLESPACE PTDB.PTITSANA
        MOVE TABLE PTI.PTAN_STMT_1200
            TO TABLESPACE PTDB.PTUTSANA
 DSNT404I SQLCODE = 610, WARNING:  A CREATE/ALTER ON OBJECT
          PTDB.PTITSANA HAS PLACED OBJECT IN ADVISORY REORG PENDING
REORG TABLESPACE PTDB.PTITSANA
      LOG            NO
      COPYDDN        PTICOPY
      UNLDDN         PTIUNLD
      DISCARDDN      PTIDISC
      SHRLEVEL       CHANGE
Once the UTS conversion process has been completed successfully, utilize the following Post Install tasks to cleanup obsolete PTDB objects introduced with PTF LU10079 in level set 20.0.8.
This provided three new Post Install tasks
  • ssid0005 - Report on Obsolete PTDB Objects
  • ssid0006 - Stop Obsolete PTDB Objects
  • ssid0007 - Drop Obsolete PTDB Objects
For further details on the requirement for the REORG, please refer to the IBM documentation: Moving tables from multi-table table spaces to partition-by-growth table spaces
