There is an issue seeing a data view when checking files in or out from Harvest under a project as no folders are visible to choose. In Workbench, when expanding the data view for the project and state, no folders are visible, not even the top-level repository folder.
Harvest Software Change Manager all versions, operating systems, and DBMS's
There are a few reasons why this might occur:
For cause #1, in Administrator Tool, add a repository to the project's baseline.
For cause #2, request that the DBA restart the database. Then restart the SCM Broker and check to see if the problem persists.
More information about configuring the project's baseline can be found here: Administrate Projects and Lifecycles
More information about restarting the broker can be found here: Restarting the Harvest Broker
