Idea to Project conversion: Default does not get set
Article ID: 370408
Updated On: 06-20-2024
Clarity PPM On Premise
Clarity PPM SaaS
Scenario under consideration:
- Custom Static lookup defined
- A custom attribute defined to use this lookup in the Project object only
- A default is set against the attribute
- Some Project templates are updated to contain a value against this newly created attribute
- Note that an equivalent attribute is not present in the Idea object
- An Idea is converted to a Project.
What are the expected outcomes for this attribute?
Expected outcomes:
- If one of the templates mentioned in step 4 is used, then the value set against the template is set against the converted Project
- Without using a template, the default set against the attribute definition is set against the converted Project
- A template that does not have a value set against the attribute is used, then no value is set against the attribute in the converted Project.
Feedback
Was this article helpful?
thumb_up
Yes
thumb_down
No
