Hub gui is not opening for a secondary hub
Article ID: 369522
For one secondary hub the hub gui in IM is not working. When double-clicking the hub probe nothing happens. In the same IM, we are able to open all other hubs.
There is a corruption in is hub.cfg file under <tunnel> section as below due to which this problem is coming.
<certs>
         <2>
           organizationName = xxx
           organizationalUnitName = Operations
            commonName = xx.xxx.x.xxx
            notAfter = -1888247609
         </2>
  </certs>
  •  Please remove  "-" from notAfter field as highlighted above because notAfter can not be negative value.
  • Restart the nimsoft watcher service on problematic hub
