How to identify next-hop edge node for Tier-1/Tier-0 gateways in active-active mode
Article ID: 369271
VMware NSX VMware vSphere ESXi
For Tier-1/Tier-0 gateways in active-active mode 'get logical-router <uuid> forwarding' will show two default routes in the forwarding table with gateway pointing to both edges. This KB provides steps to identify correct edge node used for a particular flow from a specific host.
VMware NSX-T Data Center
VMware NSX
In the below example, there are two default routes in forwarding table of this particular router. This is a Tier-1 router in Active/Active HA mode.
[root@esx:~] nsxcli
esx.example.local> get logical-router 2214affb-####-####-9d85-bd5fda6d73eb forwarding
Wed May 22 2024 UTC 08:02:12.113
                                       Logical Routers Forwarding Table
Flags Legend: [U: Up], [G: Gateway], [C: Connected], [I: Interface]
[H: Host], [R: Reject], [B: Blackhole], [F: Soft Flush], [E: ECMP]
                   Network                               Gateway                Type               Interface UUID
0.0.0.0/0                                              169.#.#.2              UGE     348953c8-####-####-be05-88edcf7b83a6
0.0.0.0/0                                              169.#.#.1             UGE     348953c8-####-####-be05-88edcf7b83a6
For this particular flow from source 172.#.#.# to destination 8.#.#.88, run the following command on source host (where VM 172.#.#.# resides) to identify correct gateway.
Command syntax -
[root@esx:~] net-vdr -R -o resolve -e <source-ip> -i <destination-ip> <logical-router-UUID>
[root@esx:~] net-vdr -R -o resolve -e 172.#.#.# -i 8.#.#.88 2214affb-####-####-9d85-bd5fda6d73eb
DR 2214affb-####-####-9d85-bd5fda6d73eb Route Table
Legend: [H: Host], [B: Blackhole], [F: Soft Flush] [!: Reject] [E: ECMP]
Destination      GenMask          Gateway          Flags    Ref Origin   UpTime     HitCount   Lif UUID
0.0.0.0          0.0.0.0          169.#.#.2      UGE      3   618619     113224     348953c8-####-####-be05-88edcf7b83a6
[root@esx:~]
To find out which edge holds the gateway, login to each edge and check interface IP address.
1. Get all logical routers on the edge.
edge> get logical-routers
2. Note VRF number and login to the correct SR router using its VRF ID. For e.g. if here VRF is 1.
Logical Router
UUID                                   VRF    LR-ID  Name                              Type                        Ports   Neighbors
79e84490-####-####-####-####077aa3c7   1      2      SR-T0-####-01                  SERVICE_ROUTER_TIER0        7       5/50000
edge> vrf 1
3. Now check interface IP address.
edge(tier0_sr[1])> get interfaces | more
Option '| more' will display output one page at a time.
Here is an example -
    Interface     : d52012e1-####-####-####-####321c0287
    Ifuid         : 283
    Fwd-mode      : IPV4_AND_IPV6
    Mode          : lif
    Port-type     : backplane
    IP/Mask       : 169.#.#.1/25;fe80::50:####:####:4452/64(A)
Return path for traffic originating from outside NSX entering NSX edge will be determined by uplink ToR switch.
