Processes in PAM are queuing up and not moving beyond the first operator and causing a backup of processes to collect in the PAM backlog
Release 4.4 or higher
CA Process Automation
c2o.log and server.log will both reveal:
c2o.log:
20XX-XX-XX XX:XX:XX,XXX ERROR [com.optinuity.c2o.servicegroup.process.StartProcessServiceOperationRunner] [ Thread-273] Error while reading process outputs from XXXX-XXXX-XXXX-XXXX - reason For input string: "2MB"
server.log:
20XX-XX-XX XX:XX:XX,XXX ERROR [stderr] (XXXX-XXXX-XXXX-XXXX) Exception in thread "XXXX-XXXX-XXXX-XXXX" java.lang.NumberFormatException: For input string: "2MB"
Review the OasisConfig.properties file located in X:\Program Files\CA\PAM\wildfly\standalone\.config. Look for any entries that contain "2MB" The value should be just "2" (no MB value needed).
Example entry:
oasis.response.payload.size.threshold=2MB
Corrected entry:
For the above setting, the default value is 4
We strongly recommend it through the UI (configuration tab) and not directly in the OasisConfig file.
Please see also existing documentation that describes the above setting (not visible by default)
