Edge VM Present In NSX Inventory Not Present In vCenter".GET /api/v1/transport-nodes/<tn-id>/state API returns transport node could not be found.POST https://<nsx-manager>/api/v1/transport-nodes?action=clean_stale_entries API runs successfully.VMware NSX
This issue is resolved in VMware NSX 4.2.0 and later, available at Broadcom downloads.
If you are having difficulty finding and downloading software, please review the Download Broadcom products and software KB.
Workaround:
To resolve the issue, try to clear the alarm using the API POST https://<nsx-manager>/api/v1/alarms/<alarm-id>?action=set_status&new_status=RESOLVED
Note: Update the <alarm-id> in the API before running it.
phonehome-coordinator service on all the manager nodes/etc/init.d/phonehome-coordinator status #Check the status of phonehome-coordinator/etc/init.d/phonehome-coordinator restart #Restart the phonehome-coordinator serviceproton service on all the NSX manager nodes. /etc/init.d/proton status #Check the status of proton service/etc/init.d/proton restart #Restart the proton service
