SDM does not load on IIS with NTLM after an upgrade
Article ID: 368586
CA Service Management - Service Desk Manager CA Service Desk Manager
After upgrading to 17.4 RU2 from RU1, SDM IIS SSL URL does not load.
This occurs when having in NX_ROOT\NX.env:
@NX_STRIP_DOMAIN_NAME=No
@NX_LDAP_ENABLE_AUTO=Yes
If NX_STRIP_DOMAIN_NAME is set to Yes, the issue does not occur
If NX_LDAP_ENABLE_AUTO=Yes is not installed, the issue does not occur.
NX_ROOT/log/stdlog show the following errors:
Lost connection to virtdb bopLDAP:
 <SERVER> domsrvr:wsp            16212 ERROR        sql_prod.c             567 Lost connection to virtdb bopLDAP
Loss of connection to process has been detected:
 <SERVER> domsrvr:wsp            16212 SIGNIFICANT  connmgr.c             2560 Loss of connection to process (ID|bopLDAP) has been detected
LDAP agent prov#XXX_bopLDAP going down:
 <SERVER> ldap_agent_nxd         16116 SIGNIFICANT  ldap_agent.c           629 LDAP agent prov#ID_bopLDAP going down
Daemon ldap_virtdb died: restarting:
 <SERVER>pdm_d_mgr               5656 ERROR        daemon_obj.c          2000 Daemon ldap_virtdb died: restarting
Event viewer shows:
Faulting application name: ldap_virtdb.exe, version: 17.4.2.168
SDM 17.4 RU2
SDM integrated with LDAP
Defect with 17.4 RU2
The solution to this defect is included in 17.4 RU3 and later releases.
