HA Config for Hub to Hub Failover including probe and queues operation
Article ID: 368185
CA Unified Infrastructure Management On-Premise (Nimsoft / UIM) CA Unified Infrastructure Management SaaS (Nimsoft / UIM) DX Unified Infrastructure Management (Nimsoft / UIM)
  • Customers often ask for guidance on how to configure hubs for failover so remote/secondary hubs can act as 'paired' failover hubs where remote (agentless) probes have been deployed. This currently only applies to an environment that doesn't use/rely upon MCS for probe/profile deployment.
  • The HA probe can be used for infrastructure components' high availability, but it does not support monitoring probes with MCS-based configurations to failover.
  • This feature/functionality may be considered in a future release.
  • DX UIM 20.4 or higher
  • Guidance
  • Hub failover/Proxy failover example scenario
Sample HA Config for Hub-to-Hub Failover including probe and queues operation
Probes installed and running on Secondary in normal mode of operation:
HA Probe installed and configured on <ABC>_Secondary 'watching' <ABC>_Primary.
Queues and probes listed below from the HA.cfg on a Secondary hub:
<queue_up>
   queue_0 = action_manager
   queue_1 = alarm_manager
   queue_2 = data_engine
   queue_3 = ems
   queue_4 = event_manager
   queue_5 = HAProxy01_AlarmDiscovery
   queue_6 = HAProxy01_QOS
   queue_7 = HAProxy02_AlarmDiscovery
   queue_8 = HAProxy02_QOS
   queue_9 = legacy_alarm_manager
   queue_10 = probeDiscovery
   queue_11 = udm_inventory
</queue_up>
<queue_down>
   queue_0 = Secondary_QOSDiscovery
</queue_down>
<probes_up>
   probe_0 = data_engine
   probe_1 = ems
   probe_2 = ace
   probe_3 = wasp
   probe_4 = qos_processor
   probe_5 = discovery_server
   probe_6 = mpse
   probe_7 = maintenance_mode
   probe_8 = udm_manager
   probe_9 = sla_engine
   probe_10 = trellis
   probe_11 = service_host
</probes_up
  • Configure data_engine with the same credentials as the Primary data_engine and verify it can login to the database. It is ok to start the data_engine and have them both running for a limited amount of time but make sure that the distsrv is deployed and kept up and running otherwise the data_engine will not start.
  • Deploy and configure the AdminConsole on <ABC>_Secondary Hub:
    How to install a second instance of the web-based Admin Console application on a secondary hub
  • Secondary hub is configured for adminconsole on port 80
    http://<hostname or IP_ADDRESS>
HA Queues need to be configured, but disabled on the Secondary. They will be enabled by the HA probe on failover, with some connecting to other hubs/Proxy Hubs.
  • The Secondary_QOSDiscovery Queue connects to the Primary Hub during normal operation and is disabled on failover.
  • Nas replication is running between Primary and Secondary during normal operation so no Alarm Queue is needed.
Proxy Fail-Over
The Proxy hub fail-over is straightforward with the 2 <City/Location> Proxy hub servers watching each other, ready to pick up the tertiary Hub Queues if one should fail.
<ABC>_Proxy01 ç=è <ABC>_Proxy02
<ABC>_Proxy01 watches <ABC>_Proxy02 which manages Queues for <ABC>_SiteHub03 and 04.
Example in HA.cfg on <ABC>_Proxy01 which will have Queues enabled if <ABC>_Proxy02 stops.
<queue_up>
   queue_0 = HASiteHub03_AlarmDiscovery
   queue_1 = HASiteHub03_QOS
   queue_2 = HASiteHub04_Alarmdiscovery
   queue_3 = HASiteHub04_QOS
</queue_up>
<ABC>_Proxy02 in turn watches <ABC>_Proxy01 and will enable its Queues to SiteHub01 and 02 if needed.
Using the Infrastructure Manager (IM), under hub->Advanced Settings->General, make sure the ‘paired’ hubs are configured with the same origin. This is important for all high-availability scenarios.
