Observed the following message....
DD.MM.YY SXXXXXXX DSB7 DC980227 V1 RPI1 CADSXXXX Recovering From Database Deadlock
Which is normal and means 2 reports, of the same report/jobname, are processed by different RPI tasks; deadlocking trying to access report processing option definition data. No need to be concerned as the task recovers and moves on to try again until it obtains good access to the data.
Then at the end of the joblog there is....
DSB7 DC970301 V1 Abend Completion Code is: SEA1
Which has occurred because the main task Dispatch was cancelled while the MSG sub task was still processing.
This is normal outcome when you cancel the main Dispatch task with an active subtask running.
The customer's automation had a 3 minute delay between issuing a Stopcads command for Dispatch, and if Dispatch was still up after 3 minutes, it issued a cancel command.
Needed to add a bigger delay to allow Dispatch to finish doing all it needs to, so it can shutdown gracefully.
