How to display ESP Maintenance Level
Article ID: 367614
Updated On: 05-13-2024
ESP Workload Automation
Need command to display ESP Maintenance Level
ESP Workload Automation 12.0
ESP Maintenance Level can be displayed by any of the methods below: (in this example the release level is 12.0.04)
1. From ESP ISPF Main Menu ie:
---- CA Workload Automation ESP Edition r12.0.04 ----
2. By issuing command 'OPER STATUS' in page mode ie:
OPER STATUS
ESP1977I ESP release 12.0.04 status
ESP1978I EVENT SCHEDULING ACTIVE
ESP1979I DATA SET TRIGGERING ACTIVE
3. In ESP started task JESMSGLG ie:
499I ESP RELEASE 12.0.04 INITIALIZED, SUBSYS xxxx
