Using CA Client Automation Remote Control Effective Settings
Article ID: 35812
CA Automation Suite for Data Centers - Configuration Automation CA Client Automation - Asset Management CA Client Automation - IT Client Manager CA Client Automation CA Client Automation - Remote Control CA Client Automation - Asset Intelligence CA Client Automation - Desktop Migration Manager CA Client Automation - Patch Manager
Question:
             In CA Client Automation how do you test what Permission a User has to Remote Control an Agent ?
Environment:
              CA Client Automation -  All Versions
              Windows                  -  All versions
Answer:
              To test what Remote Control settings you have , you can use Effective Settings
   1. )  Right-Click on the Agent you want to Test and Select:
          Remote Control > Effective Settings...
<Please see attached file for image>
 This will open the Select User Screen
    2.)  Select from Available Directories which Directory your User name is in :
          For my Example
        ca.com           is my Active Directory Account(Domain Account)                              lamgo01-u134732 is my Domain Manager (Local Account)
        3.) Enter the name of the Account, you want to check the permissions for in the Names(multiple principals can be separated by a semicolon)
        4.) Next select Add to list  - this will fill in the List of Security principals field
         5.) Select OK
The next screen will either be  the Effective Remote Control Permissions Screen
which will show you the Effective permission that account has on the machine.
OR
You will see an Error Message Screen which means you have No permission to that Agent.
Release: UASIT.99000-12.8-Asset Intelligence
Component:
1558699483947000035812_sktwi1f5rjvs16oo2.jpeg get_app
1558699482131000035812_sktwi1f5rjvs16oo1.jpeg get_app
1558699480305000035812_sktwi1f5rjvs16oo0.jpeg get_app
1558699478238000035812_sktwi1f5rjvs16onz.jpeg get_app
1558699476301000035812_sktwi1f5rjvs16ony.jpeg get_app
