IBM Unload Utility Model using RC/Migrator
Article ID: 35465
Updated On: 07-02-2024
RC/Migrator for DB2 for z/OS RC Compare for DB2 for z/OS
The IBM Unload Utility Model has been added to the standard @DEFAULT Utility Model in RC/Migrator for Db2 for z/OS (RCM) release r19.
The model utility element is: IBMULD
There is an RC/Migrator Model symbol that can be used to generate IBM TEMPLATE or otherwise generate a normal .ALLOC batch processor dataset allocation.
Look in the symbol list:
UTILITY   OBJ DESCRIPTION                SIZE
IBMULD    T   IBM UNLOAD                 RPI
CMD SYMBOL    ERR  REPLACEMENT VALUE
 _  ALLOC1         %CALC(%ROWLEN+6*%NROWS/%BYTETRK*60/100+1)_______________
 _  ALLOC2         %CALC(%ROWLEN+6*%NROWS/%BYTETRK*30/100+1)_______________
 _  DATACLAS       ________________________________________________________
 _  DATADSN        %DSN..DA________________________________________________
 _  DISK           SYSDA___________________________________________________
 _  DSN            %USERID..%DSNQUAL2..%DSNQUAL3..D%DATE..T%TIME___________
 _  LABEL          SL______________________________________________________
 _  LARGE          50000___________________________________________________
 _  MGMTCLAS       ________________________________________________________
 _  PARTDSN        %DSN..P&PART..DA________________________________________
 _  STORCLAS       ________________________________________________________
 _  TAPE           CART____________________________________________________
 _  UNIT           %DISK___________________________________________________
 _  USETMPLT       YES_____________________________________________________
 _  VOLLIMIT       ________________________________________________________
 _  VOLSER         ________________________________________________________
The USETMPLT symbol is set to YES to generate an IBM TEMPLATE statement.
If USETMPLT is not = YES then a batch processor .ALLOC statement is generated.
The generated Utility Statements look like:
<<< %USETMPLT = NO >>>
-- FROM IBMULD
.ALLOC FI(SYSCTL00) DUMMY
.ALLOC FI(UNLDDSN)                                                     +
     DA('authid.dbname.TID28.D201019.T2105326.DA')                  +
       TRACKS                                                          +
       SPACE(1,1)                                                      +
       UNIT(SYSDA)                                                     +
       NEW CATALOG
.CALL UTIL UNLOAD PARM(ssid)
.DATA
UNLOAD
FROM TABLE authid.table
  HEADER     NONE
  LIMIT      ALL
  NOPAD
  UNLDDN     UNLDDSN
  SHRLEVEL   REFERENCE
.ENDDATA
-- END OF IBMULD UTILITY
<<< %USETMPLT = YES >>>
-- FROM IBMULD
.DATA
TEMPLATE UNLDDSN DSN 'authid.dbname.TID28.D201019.T2055200.DA'
         SPACE CYL
UNLOAD
  HEADER     NONE
  LIMIT      ALL
  NOPAD
  UNLDDN     UNLDDSN
  SHRLEVEL   REFERENCE
.ENDDATA
The IBM Unload can be coupled with an IBM LOAD or a Fast Load for data load operations simply by switching the load utilities using the "X" line command in the model as usual.
