Symptoms:
You will see the following in the data_engine log:
Jul 30 14:09:44:927 [4004] de: ######################## START ########################
Jul 30 14:09:44:927 [4004] de: NimBUS Data Engine 7.62 [Dec 4 2010]
Jul 30 14:09:44:927 [4004] de: Nimsoft Corp (C) 1998-2010
Jul 30 14:09:44:927 [4004] de: port=48004 PID=976 debug=0
Jul 30 14:09:44:989 [4004] de: GetLicense - SLM-QOS error
Jul 30 14:09:45:005 [4004] de: GetLicense - SLM-QOS error
Jul 30 14:09:45:020 [4004] de: GetLicense - SLM-SLA error
Jul 30 14:09:45:036 [4004] de: GetLicense - SLM-SLA error
Jul 30 14:09:45:052 [4004] de: GetLicense - SLM-GUI error
Jul 30 14:09:45:067 [4004] de: GetLicense - SLM-GUI error
Jul 30 14:09:45:067 [4004] de: License SLM-QOS:
Jul 30 14:09:45:067 [4004] de: License SLM-SLA:
Jul 30 14:09:45:067 [4004] de: License SLM-GUI:
Jul 30 14:09:45:161 [4004] de: Unable to get a valid SLM-QOS license (error)
Resolution:
- Check distsrv if it is active
- If distrsrv is active, check its logs for any errors
- Verify NMS Manager ->Security -> Probe Administration has an entry fo data_engine
<Please see attached file for image>
