Question:
Is CA Endevor SCM Integration for the Natural Environment (EINE) compatible with Adabas v8.3?
Environment:
All supported versions of EINE
Answer:
Yes, all supported versions of EINE are fully compatible with Adabas v8.3. No additional maintenance or compatibility fixes are needed.
