Limitation of NSX-T edge multi vtep scenario
Article ID: 345837
VMware NSX VMware vSphere ESXi
In Edge Multi vtep scenario, disconnecting one vNIC on the Edge causes all traffic to drop
VMware NSX-T Data Center
VMware NSX-T Data Center 3.x
VMware NSX 4.x
In Edge multiTEP configuration, when a VNIC of the Edge VM is disconnected, in the current implementation, the failed TEP IP and MAC are moved to another vNIC. If the host switch is not configured in promiscuous mode or with MAC learning, the traffic is blackholed.
This is a product limitation
Workaround:
  • Enable promiscuous and Forged Transmits mode to accept.
    • Login to vcenter server
    • Go to Menu > Networking > Distributed Switch > Portgroup
    • Right click on port group Edit setting
    • Click Security > Promiscuous mode Accept > Forged transmits Accept.
