Flow cache is disabled on NSX Edge node
Steps to Resolve
For 4.1.1 and higher
Recommended Action:
This alarm is automatically resolved upon re-enabling of flow cache.
set dataplane flow-cache enabled' Edge CLI. restart service dataplane' Edge CLI. Maintenance window required for remediation? Yes
