Edge flow cache deactivated alarm
Article ID: 345788
VMware NSX Networking
Title: Alarm for edge flow cache deactivated
Event ID: edge_health.flow_cache_deactivated
Alarm Description
- Purpose: The purpose of this alarm is to notify users when flow cache is disabled.
- Impact: Flow cache being disabled leads to potentially impacting the overall edge throughput.
Flow cache is disabled on NSX Edge node
Steps to Resolve
For 4.1.1 and higher
Recommended Action:
This alarm is automatically resolved upon re-enabling of flow cache.
- To enable flow-cache on the Edge node to run '
set dataplane flow-cache enabled
' Edge CLI.
- Restart dataplane after Flow Cache is enabled using '
service dataplane restart
' Edge CLI.
Maintenance window required for remediation? Yes
Feedback
thumb_up
Yes
thumb_down
No
