vCLS virtual machine fails to power ON
Article ID: 344779
VMware vCenter Server VMware vSphere ESXi
Symptoms:
  • Unable to power on the vCLS virtual machine.
  • Only one vCLS virtual machine is deployed in the cluster.
  • The following message appears in the eam.log and vpxd.log of the vCenter Server: "Feature 'bad_requirement:hv.capable' was 0, but must be at least 1."
eam.log:
[YYYY-MM-DDTHH:MM:SS] | ERROR | cluster-agent-2 | AuditedJob.java | 59 | JOB FAILED: [#1182617302] PowerOnVmJob(ClusterAgent(ID: 'Agent:69812e75-5135-4541-958b-23aa572487c7:null'))
        at com.vmware.vim.vmomi.client.http.impl.HttpExchange.invokeWithinScope(HttpExchange.java:54) ~[vlsi-client.jar:?]
        at com.vmware.vim.vmomi.client.http.impl.TracingScopedRunnable.run(TracingScopedRunnable.java:24) ~[vlsi-client.jar:?]
        at com.vmware.vim.vmomi.client.http.impl.HttpExchangeBase.run(HttpExchangeBase.java:51) ~[vlsi-client.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Caused by: com.vmware.vim.binding.vim.fault.GenericVmConfigFault: Feature 'bad_requirement:hv.capable' was 0, but must be at least 1.
vpxd.log:
[YYYY-MM-DDTHH:MM:SS] info vpxd[06809] [Originator@6876 sub=Default opID=7325e956-01] [VpxLRO] -- ERROR task-88155 -- vCLS (1) -- Datacenter.ExecuteVmPowerOnLRO: vim.fault.GenericVmConfigFault:
--> Result:
--> (vim.fault.GenericVmConfigFault) {
-->    faultCause = (vmodl.MethodFault) null,
-->    faultMessage = (vmodl.LocalizableMessage) [
-->       (vmodl.LocalizableMessage) {
-->          key = "msg.featurecompat.requirement.number.minimumNotMet",
-->          arg = (vmodl.KeyAnyValue) [
-->             (vmodl.KeyAnyValue) {
-->                key = "1",
-->                value = "bad_requirement:hv.capable"
-->                key = "2",
-->                value = "0"
-->                key = "3",
-->                value = "1"
-->          message = "Feature 'bad_requirement:hv.capable' was 0, but must be at least 1."
-->          key = "msg.moduletable.powerOnFailed",
-->                key = "1",
-->                value = "FeatureCompatLate"
-->          message = "Module 'FeatureCompatLate' power on failed. "
-->          key = "msg.vmx.poweron.failed",
-->          arg = <unset>,
-->          message = "Failed to start the virtual machine."
-->    reason = "Feature 'bad_requirement:hv.capable' was 0, but must be at least 1."
-->    msg = "Feature 'bad_requirement:hv.capable' was 0, but must be at least 1."
VMware vCenter Server 7.0.x
VMware vCenter Server 8.0.x
VMware ESXI 7.0.x
VMware ESXI 8.0.x
If the "vhv.enable = true" parameter is set in the /etc/vmware/config file on the ESXi host, the system attempts to enable Intel VT-x/AMD-V when the vCLS virtual machine powers on. However, the vCLS virtual machine is not compatible with Intel VT-x/AMD-V, so it fails to power on.
To resolve this issue, disable the vhv.enable setting on the ESXi host:
  1. Place the target ESXi host in maintenance mode.
  2. Connect to the ESXi host via SSH and log in as the root user.
  3. Run "vi /etc/vmware/config" to open the configuration file.
  4. Comment out (#) the vhv.enable setting.
    Before:
    vhv.enable = true
    After:
    #vhv.enable = true
  5. Reboot the ESXi host.
  6. Exit maintenance mode.
Note: If hardware virtualization is required for a specific virtual machine, please enable "Hardware Virtualization" (Expose hardware assisted virtualization to the guest OS) on a per-virtual machine basis while the virtual machine is powered off.
Expose VMware Hardware Assisted Virtualization
vCLS 仮想マシンのパワーオンに失敗する
