To power-on, the affected VM, perform below task,
Change the value from TRUE to FALSE for vFlash entry
Before you edit the vmx file, take a backup of vmx file.
cp <VM>vmx <VM>.vmx.backup Use vi editor to change the disk value
vi <VM>.vmx sched.scsi0:0.vFlash.enabled = "TRUE" and change to "
FALSE"
Suppose if the VM has many disks and you wanted to change the value for all the disk then use the sed command to change the value. For each vmdk file that is configured to use vFRC, there is a corresponding entry in the
vmx file, that controls vFRC.
In order to turn off vFRC acceleration for a given disk, download the vmx file, and change the value for .vFlash.enabled from
TRUE to
FALSEExample:sched.scsi0:0.vFlash.enabled = "TRUE"
sched.scsi0:0.vFlash.enabled = "FALSE"
1. List out all the disk which has vFRC enabled
cat <VM>.vmx | grep -i flash.enabledsched.scsi0:3.vFlash.enabled = "TRUE"
sched.scsi0:5.vFlash.enabled = "TRUE"
sched.scsi0:11.vFlash.enabled = "TRUE"
sched.scsi0:12.vFlash.enabled = "TRUE"
2. Take a backup of the VMX file
cp <VM>vmx <VM>.vmx.backup3. Use the below command to change the value from TRUE to FALSE
sed -i 's/vFlash.enabled = "TRUE"/vFlash.enabled = "FALSE"/g' <VM>.vmx 4. Confirm the changed which you have performed
#cat <VM>.vmx | grep -i flash.enabled sched.scsi0:3.vFlash.enabled = "FALSE"
sched.scsi0:5.vFlash.enabled = "FALSE"
sched.scsi0:11.vFlash.enabled = "FALSE"
sched.scsi0:12.vFlash.enabled = "FALSE"
5. after editing the VMX file, you need to reload the VM from command line or else from GUI
Command line
vim-cmd vmsvc/getallvms | grep -i <vmname>
vim-cmd vmsvc/reload <VMDI> which is noted in the above command
GUI
Select the VM in the inventory and unregister and register the VM back from datastore.
Now, try to POWER ON Virtual machine.
6. VM will be powered ON
Perform the same task for the VM which encounter the same problem.
