Performing a conversion using VMware Converter Standalone fails with the error: FAILED: Unable to start the change tracking driver
Article ID: 343768
VMware vSphere ESXi
  • Performing a conversion task with VMware Converter Standalone fails at 1%
  • The following error appears:
  • In the converter worker log file, there are similar entries:
    [02040 error 'task-2'] Agent failed to perform DeleteBitmap: converter.fault.BitmapDriverStartFault
  • The Synchronize feature was selected
VMware vCenter Converter Standalone 4.0.x
VMware vCenter Converter Standalone 4.3.x
VMware vCenter Converter Standalone 5.0.x
This issue occurs because VMware Converter Standalone attempts to convert the User Account Control ( UAC) policies on the source machine.
To resolve this issue, use one of these options:
  • Disable User Account Control.
    To turn off UAC in Windows 2008 R2 and Windows 7:
    1. Click Start > Control Panel.
    2. In Control Panel, click User Accounts. The User Accounts window opens.
    3. Click User Accounts > Change User Account Control settings.
    4. In the User Account Control Settings page, move the slider to Never Notify and click OK.
      Note: Restart the system for the changes to take effect.
To turn off UAC in Windows 2008 and Windows Vista:
  3. Click User Accounts.
  4. Click Turn User Account Control on or off.
  5. Deselect the Use User Account Control to help protect the computer option and click OK.
    Note
  • Enable Run all administrators option in the administrator approval mode.
    To enable Run all administrators in administrator approval mode :
  1. Click Start > Run, type secpol.msc, and click OK. The Local Security Policy window opens.
  2. Expand Local Policies > Security Policies.
  3. Scroll down to User Account Control: Run all administrators in administrator approval mode.
  4. Right-click User Account Control: Run all administrators in administrator approval mode and click Properties.
  5. Click Enabled and click OK.
Impact/Risks:
Enabling the policy may allow administrative accounts to execute applications with the administrative privileges without being prompted/alerted in the process.
