While the Fix is being worked on, how can VMware customers resolve the issue through a workaround?
Edit the vApp Product Properties - Configure vApp Product Properties
Right-click a vApp in the inventory and click Edit Settings.
vApp Setting | Description |
Name | Product name. |
Product URL | If you enter a product URL, a user can click the product name on the virtual machine summary page and go to the product's web page. |
Vendor | Vendor name. |
Vendor URL | If you enter a vendor URL, a user can click the vendor name from the Summary page of the virtual machine and go to the vendor's web page. |
Click OK.
Product Name should be provided as below:
vROPS | vRealize Operations Manager Appliance |
vRNI | VMware vRealize Network Insight Platform |
vRLI | VMware vRealize Log Insight |
vRA | vRealize Automation or VMware vRealize Appliance |
vRASSC | VMware vRealize Automation SaltStack Config |
vIDM | IdentityManager |
