hub queue alarms are not clearing (hub version 7.5)
Article ID: 34030
DX Infrastructure Management
NIMSOFT PROBES
In each hub set the parameter under the hub section via Raw Configure window:
queue_growth_size
to 300 (minimum)
and click Ok to restart the hub.
Acknowledge the alarms and they should no longer be displayed.
Release:
Component: UIMHUB
Feedback
thumb_up
Yes
thumb_down
No
