You can make this change from the VMware Management Interface.
- Log onto the management interface as root or other administrative user.
- Access the menu for a virtual machine, then click Configure Options.
- Click the link under Verbose Options.
- Look for IDE devices. They are prefixed with ideX:Y, where X is the bus and Y is the device number. The section appears as:
![](https://api-broadcomcms-software.wolkenservicedesk.com/attachment/get_attachment_content?uniqueFileId=1512278347088)
This block controls the settings for the CD-ROM.
- For each device that this virtual machine doesn't need to routinely access, change the startConnected value tofalse.
Note: To make the device unavailable to all virtual machines, set the present IDE attribute tofalse.
VMware recommends that you create all new virtual machines with this configuration, unless you have a specific need otherwise.
If you are working in the service console:
- Log onto the service console as root or as another administrative user with the correct permissions.
- Edit /root/vmware/guestOSname.vmx, whereguestOSname represents the name of the virtual machine.
- Find the block of data that contains the information for IDE devices, and change the startConnected value toFalse. For example:
ide1:0.present = "True"
ide1:0.startConnected = "False" ide1:0.deviceType = "atapi-CDROM" ide1:0.fileName = "/dev/CDROM"
