"data_engine" does not come up on UIM Server. Oracle client installed.
[Environment] RHEL6 + Oracle
data_engine.log
Jul 29 16:34:38:883 [140529501513504] de: NewSLM - Requesting Oracle Jul 29 16:34:38:883 [140529501513504] de: LoadDLLbyName - Failed to load: libociei.so. libociei.so: cannot open shared object file: No such file or directory
[Solution] Oracle shared library linkage procedure needs to be performed.
Please ensure you have completed this task related to link of Oracle libraries. This procedure is required for the data_engine probe.
1. Download Oracle Instant Client (ZIP) 2. unzip it. 3. Create /etc/ld.so.conf.d/oracle.conf 4. Put Oracle Instant Client path in it. 5. # ldconfig 6. # cd <Oracle Instant Client path> 7. # ldd libociei.so 8. Verify if there is no "not found".
