hostd is not responding when running test recovery or planned migration by SRM and vSphere Replication for over 10 virtual machines
Article ID: 339571
VMware Live RecoveryVMware vSphere ESXi
Symptoms:
hostd is not responding from vCenter Server when running test recovery or planned migration by SRM and vSphere Replication for over 10 virtual machines
Guest OS quiescing setting is enabled.
Test recovery or planned migration failed in step 1: Synchronize storage due to:
VR synchronization failed for VRM group: testVM_XX. A generic error occurred in the vSphere Replication Management Server. Exception details: 'java.net.SocketTimeoutException: Read timed out'.
In test recovery or planned migration, SRM triggers virtual machine's replication for protected virtual machines with creating (quiesed) snapshots at a same time. Hostd service might not manage to handle too many tasks at a time.
This is a known issue.
Workaround: To workaround the issue, reduce a number of concurrent snapshots not more than 8:
