NSX-T edge has static_routing_removed in syslog that repeats on every configuration push if static routes are configured
Article ID: 339387
Updated On: 09-12-2024
VMware NSX
There was an issue with handling of the static of static routes because of this the system is unable to infer if there was any route change for static routes so we end up with continous alarms raising.
Symptoms:
NSX-T edge has a log in syslog that repeats on every configuration push if static routes are configured
The log location is
/var/log/syslog*
this log looks similiar to
NSX 7040 - [nsx@6876 comp="nsx-edge" s2comp="nsx-monitoring" entId="########-####-####-####-########0001" tid="7040" level="ERROR" eventState="Off" eventFeatureName="routing" eventSev="error" eventType="static_routing_removed"] Context report: {"entity_id":"########-####-####-####-########0001","sr_id":"########-####-####-####-########5737","lr_id":"########-####-####-####-########e327","static_address":"ip-address"}
This error is misleading and will not cause any issues
VMware NSX-T Data Center 4.x
VMware NSX-T Data Center 3.x
Upgrade to 4.1.1 or 3.2.4
Workaround:
NA
Impact/Risks:
The logs above are repeated within syslog and can be misleading during troubleshooting into other issues
