This article provides information on the alternative Linux command to clone vmdks without powering off a virtual machine. You may want to use this command when:
- Metadata is corrupted or lost
- Part of the LUN has been over-written, for example, by an installation of ESX to incorrect LUN
This method may present some advantages over alternatives where the virtual machine is powered on:
- It is faster than Converter as data is transferred directly to SAN instead of over network
- It is possible to restart the guest operating system if the procedure fails
vmkfstools -i is not an option where:
- The virtual machine is powered on and the vmdk is locked
- You cannot create snapshot because you cannot risk an update to metadata
VMware Converter may not be an option where:
- The guest operating system is non-Windows. For example, Linux (pre-VMware Converter 4.0), Netware or Solaris
- Insufficient diskspace on LUN for snapshots continue to grow while the guest operating system is running
