The MAC address of the NIC(s) in the Linux operating system must be changed post task completion.
Note: To perform these steps, you should be familiar with Linux commands.
Redhat
- Connect to vCenter Server using the vSphere Client
- Right-click the virtual machine and click Edit Settings.
- Click Network adapter and note the MAC Address.
For example, you see a MAC Address similar to:
##:##:##:##:##:01
- Power on the Linux virtual machine.
- Open a console and log in as root.
- Change directory to etc/sysconfig/network-scripts.
- Edit "ifcfg-eth0" using a plain text editor and update the MAC address to reflect the MAC address in Step 3.
For more information, see Adding/Deleting/Editing a host entry on vCenter server or ESXi host using vi editor.
- Activate the ethernet card by running this command:
ifup eth0.
Notes:
- ifup eth0 may be required in some instances to activate the ethernet card.
- The /etc/udev/rules.d/70-persistent-net.rules may also need to be updated to the new MAC address.
SUSE
- Connect to vCenter Server using the vSphere Client.
- Select the virtual machine and click Edit Settings.
- Click Network adapter and note the MAC address. For example, you see a MAC Address similar to:
##:##:##:##:##:AA
- Change directory to /etc/sysconfig/network.
- Run this command:
ls -l if*
/etc/sysconfig/network # ls -l if*
# ifcfg-eth-id-##:##:##:##:##:BB
- Rename this file to match the MAC address in Step 3:
#mv ifcfg-eth-id-##:##:##:##:##:BB ifcfg-eth-id-##:##:##:##:##:AA
ifup eth0
Note: If the /etc/sysconfig/network/ifcfg-eth-id-MAC file (where MAC is the hardware address of the interface) does not exist, perform these steps:
- Run touch command to create the file.
For example:
touch ifcfg-eth-id-##:##:##:##:##:AA
- Set full read/write/execute permission to the file.
- Copy the contents of the /etc/sysconfig/network/ifcfg-eth0 file to the /etc/sysconfig/network/ifcfg-eth- id-##:##:##:##:##:AA file.
- Open the /etc/sysconfig/network/ifcfg-eth-id-##:##:##:##:##:AA file using a text editor.
- Add "PERSISTENT_NAME=eth0" line to the end of the file.
- Save and close the file.
- Run this command to activate the ethernet card:
ifup eth0
Note: Please refer Operating System vendor documentation for latest changes and updates related to Network Management files and applications.
