How does data_engine maintenance and retention work?
Article ID: 33704
DX Infrastructure ManagementNIMSOFT PROBES
"Delete historic data older than" should be set to a higher number than raw data, and the way it works is that after the number of days set for Raw Data are reached, it rolls it into historic tables. In other words, if you have Raw Data set to 30 days, and Historic Data set to 60 days, then from day 1-30 you will have Raw Data and on the 31st day, the oldest raw data gets put into day one of historic data.
- UIM (any version)
Data maintenance is a two-step process:
1. For raw data, look at the retention time, and for data that is older than the retention days, run a summarization query that stores the hourly summaries into the corresponding hourly (HN) table. Something similar is done to store daily (DN) summaries from the HN table. The process runs on the schedule defined by the customer. This is done in the same way, regardless of whether the table is partitioned or not. The retention days tell you how old, from midnight this morning, the rows in the RN or HN must be in order to be considered for summarization. The summarization query is very expensive, but there is no other way to do it. If the process is running smoothly, the query will only summarize one day of data for each QoS. If the process has stalled or failed for any reason, the query becomes significantly more expensive as more days need to be summarized. Database transactions exacerbate this process, but we are stuck with how the backend RDBMS works. Partitioning can have a VERY positive effect on this summarization query, since summarization and insertion occur against different partitions and there is no contention.
2. Again look at the retention time, and determine what data needs to be deleted, which was summarized above. DN data is obviously not summarized and it is just aged out as per the number of days since midnight this AM. Here is where the process is different for partitioned and un-partitioned tables:
- For partitioned tables, we simply DROP the partitions for old data on each table. Each partition holds data for 1 day. Dropping a partition is a very fast and cheap operation. It is almost instantaneous. This is why we overwhelmingly recommend partitioning databases. For UIM v8.4, we changed the default installation to enable partitioning for the database if it is supported by the backend database.
- For un-partitioned tables, the purging/pruning process is very expensive. The pruning process is driven by a temporal DELETE statement: delete from <table> where sampletime < <retention_time>. The delete operation is one of the most expensive queries that you can run on a DB. In this case, it has to scan the index for the range, re-arrange data, indexes, storage, etc.
- It is more expensive than the summarization queries in step 1.
Large Environments ***In large installations, this data purging may not finish in a 24 hour period. This results in data maintenance not finishing, which causes the summarization in step 1 to get progressively more expensive. You quickly get into a hung cycle, which can only be resolved by partitioning the DB and potentially manually deleting old data from the RN tables. The DN and HN tables are generally pretty small, so they are not an issue.
If on top of that, you have inadequate resources, poorly configured DBs, shared storage with other applications, pretty quickly, things get out of hand and degrade badly in large environments. Partitioning a large, e.g., > 1 TB, with a significant number of large tables (>100 million rows), and already overloaded/struggling DB, is like doubling the resource requirements until partitioning is completed.
You need to have enough space available on the primary filegroup to enable partitioning or you need to wait for CA UIM to support partitioning when files are not on the primary filegroup (which is at least several releases away as of the date of this Article).
