[YYYY-MM-DDTHH:MM:SS] password:[YYYY-MM-DDTHH:MM:SS] Vdcsrp failed. Error[9114] - Unwilling to performMake sure the UPN and password are correct[YYYY-MM-DDTHH:MM:SS] <class 'SystemExit'>[YYYY-MM-DDTHH:MM:SS] <class 'SystemExit'>[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: VmDirMDBGetNextUSN: failed with error (13),(Permission denied)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: InternalModifyEntry: VdirExecutePostModifyCommitPlugins - code(9114)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: VmDirSendLdapResult: Request (Modify), Error (LDAP_UNWILLING_TO_PERFORM(53)), Message (Get next USN), (0) socket (127.0.0.1)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: VmDirMDBGetNextUSN: failed with error (13),(Permission denied)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: InternalModifyEntry: VdirExecutePostModifyCommitPlugins - code(9114)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: VmDirSRPSetIdentityData (Administrator@########.local) failed, (9114)[YYYY-MM-DDTHH:MM:SS] err vmdird t@140370486695680: VmDirSrvSetSRPSecret failed (9114)(Administrator@########.local)[YYYY-MM-DDTHH:MM:SS] info vmdird t@140370520266496: Backend state set to NORMAL[YYYY-MM-DDTHH:MM:SS] info vmdird t@140370520266496: _VmDirCpMdbFile: completed making snapshot with file size 2162Mb in 18 seconds; data transfer rate: 120.1MB/sec, db last tid: 6166413shell.set --enabled trueCopyDbIntervalInSec registry value using this command/opt/likewise/bin/lwregshell set_value '[HKEY_THIS_MACHINE\Services\vmdir\Parameters]' "CopyDbIntervalInSec" "0"service-control --restart vmdird
On the target (upgraded) VCSA:
1 Log in as root through an SSH or console session on the Source vCenter Server Appliance.
2. Run this command to enable the shell:
3. Set the CopyDbIntervalInSec registry value back to 60 sec using this command /opt/likewise/bin/lwregshell set_value '[HKEY_THIS_MACHINE\Services\vmdir\Parameters]' "CopyDbIntervalInSec" "60"
4. Restart the vmdird service
