Virtual Machine Power On Failure with Disk Module Error "Object type requires hosted I/O" on ESXi
Article ID: 334561
VMware vSphere ESXi
A virtual machine (VM) fails to power on after an ESXi host failure, reboot, or a failed migration/vMotion operation.
You encounter the following error in the vSphere Client: Module 'Disk' power on failed. Cannot open the disk '/vmfs/volumes/####/####/####.vmdk' or one of the snapshot disks it depends on.
In the /vmfs/volumes/datastore/vmfolder/vmware.log, entries similar to the following are observed:
    • File system specific implementation of LookupAndOpen[file] failed
    • Object type requires hosted I/O
    • failed to open (The specified virtual disk needs repair)
  • VMware vSphere ESXi 7.x
  • VMware vSphere ESXi 8.x
An unexpected failure of the ESXi host, an unclean shutdown, or an interrupted I/O operation (such as a failed migration) can cause the virtual disk metadata to enter a "needs repair" state. This prevents the hypervisor from mounting or locking the virtual disk file.
To resolve this issue, you must verify the integrity of the VMDK file and perform a repair using the vmkfstools utility.
Caution: Ensure you have a valid backup of the VMDK descriptor and flat files (including all delta/snapshot files) before proceeding.
  1. Enable SSH access to the ESXi host and log in as root.
  2. Navigate to the directory containing the virtual machine files:
    cd /vmfs/volumes/datastore_name/vm_folder_name/
  3. Run the following command to check if the disk requires repair:
    vmkfstools -x check VM_NAME.vmdk
    • If the output shows Disk needs repair, proceed to step 4.
    • If the output shows Disk is error free, the issue may be related to file locks or stale tasks.
  4. Run the repair command on the affected VMDK:
    vmkfstools -x repair VM_NAME.vmdk
  5. Once the repair completes successfully, power on the virtual machine from the vSphere Client.
