PCI Passthrough does not work for Virtual Machine with Linux kernel 4.2 and above
Article ID: 334342
VMware vSphere ESXi
Symptoms:
  • The PCI Passthrough device does not work in a Linux Virtual Machine with kernel version 4.2 and above
  • In the vmware.log file, you see message similar to:
Enable MSIX with zero vector programmed, intr proxy will notbe set up, device:xxxx:xx:xx.x
VMware vSphere ESXi 5.5
Patches in https://lkml.org/lkml/2015/4/13/21 changed the way the Linux kernel programmed MSI-X vectors.
Older versions programs the MSI-X vector table before enabling MSI-X in the message control register but newer versions do the following:
  • Sets the MSI-X message control register to enabled + masked
  • Masks all vectors in the MSI-X table
  • Unmasks MSI-X via the message control register
  • Programs the vectors in the MSI-X table and unmasks them
This breaks the assumptions made by PCI passthru code - specifically PCIPassthruSetupInterrupt is only called when the guest touches the message control register and PCIPassthruChangeIntrSettings assumes that the message addresses have already been programmed.
To resolve this issue:
  • Upgrade the affected ESXi host to 5.5 Patch 08 or later version.
  • Upgrade the affected ESXi host to ESXi 6.0 Patch 03 or later version.
    These versions fix the problem by making PCIPassthruMSIXRPCHandler handle this case by disabling MSI-X before the guest writes the vector table and re-enabling it afterwards if MSI-X is enabled through the message control register.
Impact/Risks:
ESXi host needs to be rebooted to apply the fix.
