The object or item referred to could not be found. vDS dvs cannot be found DVS 0c 0c 29 50 36 ef c0 af-64 b8 38 91 c0 eb c0 35 cannot be found
DVS 65 e4 15 50 15 12 fc e2-66 b0 0a 53 91 f6 5b 1a cannot be found
DVS 9d c8 00 50 d8 9a fd b9-30 c1 76 88 7f a9 06 5a cannot be found
DVS 2b 10 3b 50 79 2a 87 fe-b1 fd 81 6a 84 70 2f 57 cannot be found
A virtual machine was moved from an existing vCenter with a distributed switch to a new vCenter, where the distributed switch no longer exists.
Problem can be found in multiple versions of vCenter
The virtual port ID associated with the virtual machine no longer exists.
For more information, please see the following documents.
Port Group Configuration for Virtual Machines
Connect an Individual Virtual Machine to a Distributed Port Group
