Topology information is not accurate
The Cisco Nexus Switch certification is created so that it will connect to Cisco network devices. The certification needs to be modified to allow bridging to occur. The current certification reads:
# Cisco Nexus cevChassisN3kC3048TP1GE Switch
.1.3.6.1.4.1.9.12.3.1.3.1106 {
TYPE = Switch
VENDOR = Cisco
MODEL = Nexus-C3048TP1GE
CERTIFICATION = CERTIFIED
DASLDRIVER = CiscoNexus
CONT = Cisco-Nexus-VDC-CLI
HEALTH = Nexus-Entity-EntSensor
VLAN = Cisco-Nexus-Vlan
NEIGHBOR = Cisco-Cdp
INSTRUMENTATION:
Environment = CiscoEntityFRU:DeviceID
Card-Fault = CiscoEntity:DeviceID
CPU/Memory = CiscoNexus:DeviceID
Interface-Fault = MIB2
Interface-Performance = MIB2
Port-Fault = MIB2
Port-Performance = MIB2
id2type_Cisco.conf - sm_edit ../conf/discovery/oid2type_Cisco.confsm_tpmgr -s <IP domain name> reloadoid
