Edge node issues in VMware NSX-T
Article ID: 331578
VMware NSX
Symptoms:
  • Edge node has crashed.
  • Edge node is inaccessible.
  • Accessing the console fails.
  • The physical keyboard light starts to blink.
  • In the NSX Manager User Interface (UI), MPA connectivity displays as Down.
  • VMware NSX-T
This issue occurs when the Edge VM is placed and running on an overcommitted ESXi host.
Edge is resource sensitive. If the Edge is deployed on a ESXi host which does not have dedicated resources for the Edge VM, and if the resources are overcommitted, the Edge starts experiencing:
  • Issues with bootup
  • Network connectivity
To prevent this issue:
  • Always deploy the Edge VM to an ESXi host that contains lots of CPU and Memory.
  • Do not overcommit the ESXi host by deploying too many virtual machines in it.
To recover from the issue:
  • Power off or migrate virtual machines from the affected ESXi host
