Smarts NCM: NCM Regular Expression Engine doesn't support upper and lower case validation.
Article ID: 330901
VMware Smart Assurance
Symptoms:
NCM Regular Expression Engine inside the automation library does not support the validation of upper and lower case letters.
VMware Smart Assurance - NCM
This feature is not supported and is documented in our online documentation:
  • Log into the NCM GUI and in the top tool bar click on Help and then select Help Contents (F1).
                                                           OR
  • To go https://<NCM Server>:8880/voyence//help/default.htm.
