WiFi specifications on Edge 510 and 520
Article ID: 330707
VMware SD-WAN by VeloCloud VMware VeloCloud SD-WAN
N/A
Symptoms:
Overview of  Specifications:
An Edge 510 and 520, the network standard for WiFi follow the 802.11ac  (NOT Wave 2).  It’s dual-band, but not simultaneous dual-band.
Frequency bands of Operation:
The operational Frequency Bands in GHz are
  • 2.400-2.4835
  • 5.150-5.250
  • 5.725-5.850
Radio Capabilities:
1 x 802.11a/b/g/n/ac
(Single Radio Dual Band)
Maximum Data Rate:
ModelConfigurationMax Data Rate
Edge 5102X2866 Mbps
Edge 5203X31300 Mbps
Simultaneous SSIDs:
A total of 16 simultaneous SSIDs are supported. However the VCO currently permits only up to 8.
Maximum Tx Power:
 23 dBm/chain2.4 Ghz
19 dBm/chain5.0 GHz
Antennas:
Edge 510Two Internal Antennas
Edge 520 Three Internal Antennas
N/A
N/A
Workaround:
N/A
Impact/Risks:
N/A
