You have a virtual machine that fails to power on.
Sep 21 23:19:52.728: vmx| Msg_Post: ErrorSep 21 23:19:52.728: vmx| [msg.vmmonVMK.creatVMFailed] Could not power on VM : Invalid metadata.Sep 21 23:19:52.728: vmx| [msg.monitorLoop.createVMFailed] Failed to power on VM-------
Sep 21 21:52:56 besxps01 vmkernel: 3:09:23:06.771 cpu3:1089)WARNING: Swap: 2056: Set file length failed:status Invalid metadata, length 2166784KBSep 21 21:52:56 besxps01 vmkernel: 3:09:23:06.771 cpu3:1089)WARNING: MemSched: vm 1090: 2957: insufficient swap: need=2166784Sep 21 21:52:56 besxps01 vmkernel: 3:09:23:06.771 cpu3:1089)WARNING: World: vm 1090: 911: init fn memsched failed with: Invalid metadataSep 21 21:52:56 besxps01 vmkernel: 3:09:23:06.771 cpu3:1089)WARNING: World: vm 1090: 1776: WorldInit failed: trying to cleanup.A virtual machine running on an ESXi host that will not power on.
There is likely invalid metadata on the datastore which the virtual machine resides.
