How to alarm on Cisco power supply status with Live Health
Article ID: 32811
CA eHealth
Question:
How do I alarm on power supply status for Cisco devices?
Answer:
If you want to get an alarm for all non-good states, you will need to create 2 rules, as a status of "1" means "good"
  1. Create a Live Exceptions rule, including the correct element type, "Router/Switch Environment CPU" and variable "Power Supply Status"
  2. Set your first rule to "above 1", as a gauge value
  3. Create a second rule, just like the first, but set the value to "below 1"
Additional Information:
Cisco has the following status codes for power supply
1:normal
2:warning
3:critical
4:shutdown
5:notPresent
6:notFunctioning
eHealth uses the following calculation to deal with these 6 codes
(constArrayMap (ciscoEnvMonSupplyStatus, 0,1,2,3,3,0,0))
  • When the value of ciscoEnvMonSupplyStatus is either 0, 5 or 6 -- we mark it with a value of 0
  • When the value of ciscoEnvMonSupplyStatus is 3 or 4 -- we mark it with a value of 3
  • When the value of ciscoEnvMonSupplyStatus is 2 -- we mark it with a value of 2
  • When the value of ciscoEnvMonSupplyStatus is 1 -- we mark it with a value of 1
Because of the way that eHealth handles the error codes, there is a possibility of a "0" status, thus the extra rule
Release: LHDEVC99000-6.3-eHealth-Live Health Upgrade Elements
Component:
