summarize-dvfilter | grep -A 2 <VM-name>world 3540626 vmm0:<VM-name> vcUuid:'## ## ## ## ## ## ## ## ## ##' port 67108899 <VM-name>.eth1 vNic slot 2 name: nic-3540626-eth1-vmware-sfw.2 -->> slot 2 filter, this is the DFW filtervsipioctl getrules -f nic-3540626-eth1-vmware-sfw.2
Note: When a VM or EN is added to the exclusion list, there should be no slot 2 and therefore no firewall rules applied to the VM. By default system VMs such as Edge nodes and Managers should be excluded from the DFW.
This issue is resolved in VMware NSX-T 3.2.4
This issue is resolved in VMware NSX 4.1.2
This issue is resolved in VMware NSX 4.2.0
Workaround:
