Slow power on and storage operations with the HP Smart Array P410i controller
Article ID: 326314
VMware vSphere ESXi
Symptoms:
  • Power on and storage operations are slow with the HP Smart Array P410i controller
  • If ESX becomes unresponsive on the HP Smart Array P410i and you press ALT+F12, you see the error:
    WARNING: SCSILinuxAbortCommands Failed.
    WARNING: VSCSIFs:240:handle 8192 (vscsi0:0):Failed
    hpsa0 abortingcmd 0x2a 0:0 serial:0x132902e
    hpsa :pollcomplete ():returning 1
    hpsa0:SendCmd Timeout out, No command list.
VMware ESX 4.0.x
VMware ESXi 4.0.x Embedded
VMware ESXi 4.1.x Installable
VMware ESXi 4.1.x Embedded
VMware ESXi 4.0.x Installable
VMware ESX 4.1.x
This is a known issue. For more information, see the Supported Hardware Issues section of the vSphere 4.0 Release Notes and ESXi 4.1 Update 1 Release Notes.
To resolve this issue, install the HP 256MB P-series Cache Upgrade.
Note: The preceding link was correct as of April 15, 2010. If you find the link is broken, provide feedback and a VMware employee will update the link.
