Slow virtual machine storage when using HP Smart Array P410 with ESX 3.5
Article ID: 326276
Updated On: 07-07-2020
VMware vSphere ESXi
Symptoms:
When running virtual machines on local storage using a HP Smart Array P410 or P410i controller with battery backed write cache on ESX 3.5, you may experience these symptoms:
  • Storage performance is slower compared to older generation Smart Array controllers
  • Virtual machine performance is slower than with previous Smart Array controllers
  • Local VMFS storage is not performing as expected
  • SAN storage is performing as expected
VMware ESXi 3.5.x Installable
VMware ESX Server 3.5.x
VMware ESXi 3.5.x Embedded
The HP Smart Array P410 and P410i controller is a 6G SAS based controller. In certain tests the performance is comparable to, for example, a Smart Array P800 controller (a 3G SAS based controller). However, the performance is degraded in other tests.
Note: All tests performed included the BBWC (Battery Backed Write Cache) installed and enabled on the P410(i).
HP and VMware recommend upgrading to ESX 4.0 or later.
