VM fails to power on with "vSphere HA detected an HA cluster state version inconsistency in cluster"
Article ID: 325353
VMware vCenter Server
  • Power on of VMs fail with "The virtual machine was not compatible with host (...) The host is reporting errors in its attempts to provide vSphere HA support. - The host is reporting errors in its attempts to provide vSphere HA support."
  • This error occurs both from power on triggered from vCloud Director or vCenter
VMware vCenter Server 7.0.x
VMware vCenter Server 8.0.x
If hosts are not prepared to HA this will create incompatibilities with some features such VM Monitoring
Not having HA enabled, in this case will cause the error seen
