This issue is resolved in VMware NSX-T Data Center 2.4.2, available at VMware Downloads.Workaround:
Once memory has been exhausted on the Edge VM, it has to be rebooted to workaround the issue.
If a 3rd party ingress controller is configured in the environment, it may be contributing to the high rate of configuration changes on the Edge LB. In this case please open a Support Request with VMware GSS to discuss workaround options.
